Öppna kategorin
Den Gröna omställningen.
8887 inlägg 418290 visningar 50 följer Svara, dela mm...
Re: Den Gröna omställningen.
nyrjoh
#846550 Ej längre lönsamt med offshore vind.
New
@PwC
analysis: There is no longer a financial incentive to build offshore wind in Denmark
The Danish government's ambitious offshore wind plans are threatened by economic failure due to sharp price hikes and rising financing costs.
A new PwC analysis show material prices, interest rates, and electricity price uncertainty have rendered projects unprofitable.
CapEx has risen 30% in only two years from 2,500 $/kW in 2021 to 3,240 $/kW in 2023.
The calculations shows that a pool of offshore wind projects of 9 GW (equivalent to the upcoming Danish tenders) today has become approx $6.7 billion more expensive than the same amount of offshore wind in 2021, exclusively seen in relation to changes in CapEx.
CEO og Danish trade association for insurance companies and pensions funds (F&P) Kent Damsgaard warns that without major market changes or technological breakthroughs, investors and energy companies will likely abandon Danish projects.
According to the analysis, a single offshore wind farm of 1 GW has become $2 billion more expensive in total costs.
The base case, which is based on the current investment conditions and the latest projections of
the electricity market, shows a negative result with a project value of -$460 million for 1 GW of offshore wind.
Only two years ago these projects where expected to generate a surplus of $1,5 billion.
https://energywatch.com/EnergyNews/article17172812.ece
https://x.com/sollidnuclear/status/1799832088859869453
Alvarsson
#846552 Twitterinlägg och press är en sak. Det viktigaste är vad investerarna tycker. De vill mer än gärna investera i ny vindkraft. Det journalister och andra glömmer är att dessa kostnadsökningar drabbar alla andra kraftkällor också.
Alvarsson
#846584
Alvarsson skrev:Det här vore något att satsa på i stället för att toksubventionera det fossila bränslet.
https://www.di.se/nyheter/vi-siktar-pa- ... om-sex-ar/
Frågan är bara hur miljövänligt det är? Falcon9 bränner 155 ton fotogen för att få upp 15 ton i LEO och de där 15 tonnen kommer förr eller senare att brinna upp i Jordens atmosfär.
Alvarsson
#846628 Scania, en massiv satsning på el.
https://www.svd.se/a/bmz6Ae/scania-bola ... -lastbilar
nyrjoh
#846633 https://www.facebook.com/share/r/XZbfgZCbkNR1rtYL/
Snabb genomgång av den gröna omfördelningen av pengar.
nyrjoh
#846714 https://www.tn.se/hallbarhet/37652/sven ... roduktion/
"Risken för effektbrist i Sverige har ökat väsentligt, varnar Svenska kraftnäts driftschef Erik Ek och sätter ned foten. ”Vi vill att det byggs mer planerbar produktion”, säger han till TN. Och det är bråttom med lösningar."
#846743 Jag vet inte om jag har en dålig dag eller men när jag räknar 600MWh och 80-tusen hushåll i ett dygn så får jag det till en förbrukning på 300W över dygnet.
Det kan säkert funka om du 20 grader varmt ute och ljust nästan dygnet runt samt att du lagar maten på kolgrillen.
Lagringen behövs ju när det är dunkelflaute i november till januari och då räcker 300 watt föga.
nyrjoh
#846744 https://www.di.se/live/vattenfall-gar-v ... reaktorer/
Vattenfall har beslutat att gå vidare med brittiska Rolls-Royce SMR och amerikanska GE Hitachi Nuclear Energy, som båda är leverantörer av små modulära reaktorer (SMR). Detta ses som ett nästa steg i arbetet för att möjliggöra ny kärnkraft vid Ringhals.
Alvarsson
#846778 Börjar bli tjatigt, ny vindkraftsprojekt var och varannan dag. Ytterligare ett bolag som vill göra jätteinvestering i ny vindkraft.
Hodal
#846782
Alvarsson skrev:Börjar bli tjatigt, ny vindkraftsprojekt var och varannan dag. Ytterligare ett bolag som vill göra jätteinvestering i ny vindkraft.
Tjatigt har det varit länge. Skönt att du inser det.
Alvarsson
#846795 I detta fall är verkligheten tjatig när nya investerare i en ständig ström ställer sig i kön för att kunna investera i ny vindkraft.
skogshare
#846800
Alvarsson skrev:I detta fall är verkligheten tjatig när nya investerare i en ständig ström ställer sig i kön för att kunna investera i ny vindkraft.
Vill återigen slå ett kraftfullt slag för att kombinera/integrera framför allt havsbaserade vindkraftsparker med ;
- produktion av vågkraft - ev. med bojar/pontoner som ansluts till vindkraftsfundamentet
- produktion av solkraft - genom att delvis kläda in vindkraftspelaren med solceller
- produktion av grön vätgas - där också den avskilda syrgasen från elektrolysen kan tillvaratas för bl.a. syresättning av syrefattiga havsbottnar
- kostnadseffektiv avsaltning av havsvatten i salta hav för olika angelägna ändamål.
Jag föreslår att föreslagna integrerade anläggningar benämns energikombinat.
Rotvältaren
#846802
När de verkliga kostnaderna kommer på bordet kommer kön att vara som bortblåst.
Alvarsson
#846804 Till skillnad mot kärnkraften så är de verkliga kostnaderna på bordet.
