Skotare
kockum KL 836
5 inlägg 5709 visningar 1 följer Svara, dela mm...
Rottne skotare kategori
kockum KL 836
Søren
#127448Hi
Short time ago i did buy a Kockum KL 836, build 1969. A very fine machine i a good shape. I'm planning to use the summer to rebuid the machine and therefore i need a technical manual. Is there anybody in this forum that can help me, or tell me where to find a manual
I need to have the machne finished for the forest next winter :lol:
Best regards
Søren Laursen, Denmark
Rottne skogsmaskiner
Re: kockum KL 836
mannen
#127452Hello
Here you've got an instruction manual for the kockum.
https://skogsforum.se/downloads.php?view=detail&df_id=5
Re: kockum KL 836
Søren
#127739Thank you so much for the information regarding instructions manual. I will upload some photos of my mashine later.
Kind Regards
Søren Laursen :grin:
Re: kockum KL 836
Søren
#147113Hi,
I have been working on my Kockum KL 836 all summer, and it's now almost ready for the forrest. :lol:
I do have a problem regarding the oildrives in the rear. I don't have any power in the oildrive. If I activate the oildrive on flat ground with no load on the machine, nothing happens.... :cry: ....How much power should I expect ?? :geek:
I did test the main pump. 170 Bar of pressure and approx 90-100 L/min, it seems to be ok. :P
I also did open the oildrive and it looks very nice inside...no signs of wear og no scractes
Now my question is...How do I test the oil drive ??? and what shoud I expect ??
Thank you very much
Best regards
Søren Laursen, Skanderborg Danmark
Re: kockum KL 836
#147148Hi Søren!
As you are from Denmark I presume you read Swedish without big problems. In that case there is some about the rear drive in this rather long thread: viewtopic.php?f=11&t=3142&st=0&sk=t&sd=a#p33557
There maybe more threads about this, do a search for "836" and I believe you'll find most of what's written about it here.
Torsten
