Öppna kategorin
Den Gröna omställningen.
9743 inlägg 522641 visningar 50 följer Svara, dela mm...
Re: Den Gröna omställningen.
nyrjoh
#861091 Dyrt med slumpkraft...
“When it comes to weather risk, wind power is and remains the central risk factor for the power systems in the winter months. That is because the range of possible wind power outcomes is quite wide,” said Francisco Gaspar Machado, senior power analyst at LSEG, adding that hourly prices could hit EUR 1,000/MWh or higher this winter.
In the day-ahead auction for Wednesday, German power for the hour from 17:00-18:00 CET turned out at EUR 820.11/MWh, making it the fourth-highest hourly price in the day-ahead auction this year. The highest three hours were recorded on the day the Epex Spot exchange decoupled from the other exchanges.
The country yesterday burned 700 MW of oil-fired output, one of the most expensive fuels, as wind power generation hit a 10-year low.
Low renewables risk
Wind output in Germany fell below 1 GW yesterday, compared with the seasonal norm of around 19 GW, Montel Analytics data showed.
“I expect this to happen more often this winter,” said a German power trader. “And this is just the beginning, I guess prices can go much higher the further winter progresses. This goes especially for days with low wind and solar.”
Central Europe should see “well below normal” wind generation in the weeks to come, said William Henneberg, meteorologist at Weather Commodity Group, as well as temperatures 1C warmer than usual.
In periods of low wind output, more expensive gas and coal plants enter the market to meet demand.
Sigurd Lie, senior analyst at Norwegian consultancy StormGeo, also pointed to Germany’s phasing out of coal and nuclear, which meant the baseload supply of lignite, coal and gas had “narrowed”, he said.
German hard coal capacity stood at 16.8 GW at the start of October, EEX data showed, and should drop to 10.3 GW by the end of this year. Germany aims to cut its hard coal capacity to 8 GW by the end of 2030.
Lignite output restrictions
Leag, one of Germany’s top producers of lignite-fired power, said last week it expected output reductions due to technical issues. The Jaenschwalde (2 GW), Boxberg (2.5 GW), and Schwarze Pumpe (1.5 GW) power plants would not be available at full capacity until the end of March, it added.
Germany should have “enough power, but it will be more expensive” over winter, said a German portfolio manager.
Machado expected price spikes in the mornings and afternoons throughout winter and for these to impact the monthly and front-quarter prices more than the market had currently priced in.
The front-month contract last traded at EUR 87.30/MWh on the EEX, with the front quarter at EUR 93.75/MWh.
Machado forecast further rises: “Our model is currently pricing December at EUR 99.10/MWh and Q1 at EUR 99.70/MWh in the average of weather scenarios.”
Alvarsson
#861095 Inte ens i Tjeckien!
https://www.di.se/nyheter/karnkraftsoro ... e-fi-test/
Alvarsson
#861112 Förnybar energi större än kol, olja och gas i Tysk elproduktion.
https://growsverige.se/2024/11/08/solen ... a-och-gas/
nyrjoh
#861113 När man silar mygg och sväljer kameler...
https://x.com/DerPhysiker21/status/1855 ... u-fTA&s=19
nyrjoh
#861115 Tänk om alla skulle förlita sig på grannen för strömmen som Tyskland gör nu när de lagt ned kärnkraften...
Alvarsson
#861116 Ja det är precis den inre marknaden är till för. Vi behöver inte gå längre tillbaka än år 2022, när Tysk elproduktion räddade det helt kärnkraftsberoende Franska elsystemet från total kollaps!
Rotvältaren
#861119 Behöver inte gå tillbaka många dagar i tiden när tyskt kol var det som tyskarna hade att förlita sig på, av någon underlig anledning stod vindkraftverken i stort sett stilla och solpanelerna vägrade att ge elström.
Alvarsson
#861120 Precis och hitintills i år så har det förnybara producerat mera el än det fossila, och alla har el.
nyrjoh
#861122
Alvarsson skrev:Ja det är precis den inre marknaden är till för. Vi behöver inte gå längre tillbaka än år 2022, när Tysk elproduktion räddade det helt kärnkraftsberoende Franska elsystemet från total kollaps!
Det var då det. Hur tycker du det ser ut med överskott för deras del nu när det inte blåser eller det är molnigt? Ska de veva på vindkraftsverken för hand?
Rotvältaren
#861125 Vilken osis då att tyskarna inte passade på att fylla källare och uthus med förnybar energi när det blåste...
Alvarsson
#861137
Varken ett vindkraftverk eller ett kärnkraftverk producerar el när det står stilla. Ett vindkraftverk producerar el oftare än ett kärnkraftverk alla fall i Sverige.
nyrjoh
#861141
Jadu, det är ju härligt att du har en sådan fin fantasivärld du lever i.
#861142 Jo men inte lika härligt för dom runtomkring 🤣
Rotvältaren
#861143 Så ett vindkraftverk producerar el oftare när det står stilla?
Alvarsson
#861147
Nej, det är ingen fantasivärld det är fakta ett vindkraftverk producerar oftare el en ett kärnkraftverk i Sverige.
FTG skogsvagnar
