EIA röjkniven
12 inlägg 9420 visningar 2 följer Svara, dela mm...
EIA röjkniven
Axeman
#72017Greetings to all. New member here from Canada. Sorry I have to impose my English on you, but jag kan inte tala svenska!
I have plenty of Swedish steel around here: Mora knives, E.A. Berg chisels, axes of course - lots of them(!), some Carl Gustafs in 6.5mm etc... :grin:
Anyway, my reason for posting here is I have a bush hook, as we call it in English, made by Edsbyns Industri AB ("EIA"), model 403, and I need a new handle for it!
These haven't been imported to North America for quite a few years so nothing is available here. I would make a new handle, but too many other projects on the bench!
Does anyone know where I could find a couple of spare handles for one of these?
Thanks in advance!
Re: EIA röjkniven
swe#kipp
#72022If you can post a picture of yours it would easier to point you in the right direction :)
Re: EIA röjkniven
Re: EIA röjkniven
Naders
#72030Could it possibly be one of these?
The picture is taken from a product-catalouge which you can download at: http://www.silvitec.se
Re: EIA röjkniven
Axeman
#72033Thanks for the replies! Sorry, I should have posted a photo before. This is the one I have:
Re: EIA röjkniven
swe#kipp
#72060That was an old one, I think it would be easier buy a newer model i think !?
This could be a place look at ! http://www.baileysonline.com/
I now they are in the states but they really go a long way to help there customers !!!
Re: EIA röjkniven
Axeman
#72065It is an older one I agree, but a good one.
The shank of the blade goes past the last rivet on the handle which makes it probably quite a bit stronger IMO than the newer type with the socket.
The only reason it broke was I somehow struck against the trunk of a tree about where the last rivet is. That cracked the handle. I wrapped it in wire and tape, but that failed too after a year or so.
Somewhere out there must be some of those handles still...!
Re: EIA röjkniven
swe#kipp
#72075I will look for one when i'm out searching for other old logging equipment :)
Re: EIA röjkniven
Axeman
#72296Thanks for the help everyone! The long handled versions shown above are no longer being made the factory tells me. :sad:
Re: EIA röjkniven
Axeman
#120638Well, there is a "Law of Attraction"! I happened to go into a little second-hand store and there on the shelf is a NOS axe handle and the handle from a röjkniven for $6.00!
Not exactly the same, a little older and a different company (SKOGSDON AB), but close enough.
The blade snapped right off on this one, so the EAL design is better obviously. I asked if the blade was available, but it was not.
So, one more rivet and we are in business again.
Re: EIA röjkniven
Axeman
#222971Just an update: thanks to a kind person I now have several new EIA röjkniven as shown in the photo above and they seem to be of good quality also. Only the short handle is now offered, but the handle of the "slasher" shown on the right hand side of the photo will fit the röjkniven perfectly, for those like me who want the longer handle.
Re: EIA röjkniven
#222973Skogsforum makes good even in Canada! Glad to hear you got these tools! :grin: :grin:
Nordfarm
