Valmet 911.3 with mini joystic
5 inlägg 2115 visningar 1 följer Svara, dela mm...
Olofsfors
Jozo
#835753Hello, excuse my english.
Has anyone Valmet 911.3 with mini joystic and Maxiexplorer? I bought used one, but i have not experiences with harvester.
I can't grab cutted tree from ground only with delimbing knives. Is it possible with mini joystic? I asked here in Slovakia and Czech republic, but it looks, that no one have mini joystic.
Thank you for all responses.
Skogsband från Olofsfors
Re: Valmet 911.3 with mini joystic
skogsjan695xl
#835775It shouldn't be a problem, it should be only to close at the same way you do on a forwarder.
hfab
#835779
skogsjan695xl skrev:It shouldn't be a problem, it should be only to close at the same way you do on a forwarder.
Men då stänger väl även matarhjulen?
Jag uppfattade det som att han ville kunna plocka med bara kvistknivarna.
Vilket jag förövrigt själv vill veta hur man gör...
skogsjan695xl
#835859
Ja så är det nog ja. Jag har för mig nån av knapparna på höger pallet är stäng kniv/hjul öppna.
Jozo
#835874Hello, thanks for responses, today i changed some settings in TerMan. Now is possible close knives with upper button on right joystick, and close with button on right palette. But knives pressure is very weak. Is not possiblle to lift up thin tree from ground. I found knives pressure settings, but only for delimbing, not for grabbing. Has someone any idea how to solve it?
