How to properly set up a clearing saw harness?
3 inlägg 1218 visningar 1 följer Svara, dela mm...
DaveCain
#805784Hello! When using a clearing saw, I frequently experience shoulder ache. Is there anyone here that knows how to properly set up a clearing saw harness? Thank you ahead of time!
Re: How to properly set up a clearing saw harness?
#805785A photo or brand/model of the one you have would promote getting guidance.
There are instructions to find somewhere as well as at the same time there are better and worse designs. Otherwise, generally speaking. Where it cuts deepest in the flesh is where to extend the webbing to find balance near you centerline.
And still there is 10kg/25lb you need to take and it wont levitate.
Myself like the older and less over-engineered ones over the modern, which I find over-complicated.
#805814If you have a more advanced harness, you should aim for 50% weight on your hips and 50 % on your shoulders, there both shoulders cary equal weight.
For forestry clearing, the hitch should be about 10-15 cm below your waist, and the blade be parallell to the grund, about 20-30 cm above the ground.
Stihl
