ANSI B175.1 krav på sågar större än 62cc
1 inlägg 2247 visningar 1 följer Svara, dela mm...
traktorz
#228361ANSI standard B175.1 (krav på sågar större än 62cc)
Kanske ni som har motorsågskörkort är hemma på dessa amerikanska säkerhetskrav? Har vi något liknande inom EU, eller här på hemmaplan? Såg just att jänkarna har en indelning i sågar mindere/större än 3.8 cubic inch (62cc).
Nu har vi vår största såg på 59 cm³, en Stihl MS362 så den ligger nedom den aktuella brytningsgränsen. Vi har inte behov av någon större såg heller.
Från Oregons informationssida:
What is ANSI?
Certain provisions of the safety standard known as the "ANSI (American National Standards Institute) B175.1" contain requirements designed to reduce the risk of injury from chainsaws sold in the United States. The following information should be used as a guide for the selection of appropriate replacement chains and guide bars in order to maintain compliance with the ANSI standard (United States only).
The ANSI standard B175.1 divides all chain saw power heads into two groups:
- Under 3.8 cubic-inch (62cc) engine displacement, the chain meets the standard and is identified by green markings or labels.
- 3.8 cubic inch (62cc) and larger, the chain DOES NOT meet the standard and is identified by yellow markings or labels.
Saws 3.8 cubic inches (62cc) and larger may, but are not required to, comply with ANSI low-kick-back provisions. These saws are not recommended for general use and may be capable of kickback that could result in serious injury. Larger saws should be operated by users with experience and/or specialized training for dealing with kickback.
When replacing chain on saws less than 3.8 cubic inches (62cc), any low-kickback chain of the proper pitch and gauge can be used. OREGON® identifies and labels all low-kickback chain in green. OREGON® safety features greatly reduce the hazard of kickback while maintaining high cutting performance. However, ALL CHAINS CAN KICKBACK, which may result in severe personal injury to the saw operator or bystander.
Ref:
Oregon AppGuide
http://www.oregonproducts.com/AppGuideMoreInfo.htm
Nordfarm slirskydd
