Wisenten blev skotarledare så full pott för Vieremäfabriken
Källa enligt tidningen Metsätrans http://www.metsatrans.com/
Statistiken gäller inregistrerade NYA maskiner i Finland.
Skördare
Ponsse
Ergo...........26 st år 2010,16 st år 2009,65 st år 2008
Beaver....... 22 ..............13.................68
Wisent Dual..1 ................1..................1
Bear............ - ................-..................-
Fox ............ 33 ..............-...................-
JD
770 ..........1 ...................-.................-
1070 ........ 8 ...................6................35
1170..........22 ...................4................-
1270..........22 ..................4.................30
1470..........1 ..................-...................3
Valmet
901............21 ................12...............24
911............19 .................11...............33
931.............2 ..................-.................-
Övriga
................ 16 ...................12...............33
Skotare
Ponsse
Gazelle...... 2.....................3..................4
Wisent.......27 ...................9.................55
Elk............ 22....................6..................38
Buffalo........12....................13................42
Elephant .....1 ....................1..................3
JD
810 ..........6......................2.................14
1010.........19...................2..................23
1110.........11....................5.................43
1210.........17 ...................1...................-
1410 ........ -......................-..................13
1510 .........2 .....................2..................-
1710 ........ - ....................-...................-
Valmet
830.......... 6......................8..................34
840..........16....................3..................29
860...........5.....................1..................4
Övriga
...............5......................2..................24
Samlar på grönt skrot,ja och lite rött oxå....
när man gick över till 1410 kändes det som man fick en maskin som va en meter högre nästan, tror det är rexroth som kan ha dåliga dagar ibland vet en 1070D som dom bytte pump på två ggr på 9000 timmar samma var det med ponsse dom hade trassel med parkerpumparna ett tag sen gick dom över till rexroth då blev det bättre
