Skogsmiljö och Trädlära
Halvering av vargstammen till 170 individer nu beslutat
138 inlägg 18849 visningar 16 följer Svara, dela mm...
Re: Halvering av vargstammen till 170 individer nu beslutat
nyrjoh
#891985Fortsatt inga problem med vargen ute i Europa. Bara en liten ökning av antalet attacker på 40% jämfört med förra året. Men det är lugnt!
https://www.hartvannederland.nl/milieu- ... 40-procent
Number of wolf attacks has risen sharply: an increase of 40 percent
Aug 21, 2025, 10:43 AM
The number of wolf attacks on sheep and other livestock has increased significantly, according to data from BIJ12, an organization that handles wolf cases for the province. In the first six months of 2025, 497 attacks on animals were recorded, compared to 360 in the same period a year earlier.
In about 85 percent of all cases, landowners had not taken sufficient preventive measures to prevent damage by wolves, according to data from BIJ12.
Wolf Bram recently attacked a young child, which led to the closure of his area. The video below tells you more about this latest incident involving Wolf Bram:
Child bitten and dragged away by wolf in forest near Austerlitz
2:09
The actual number of attacks could be even higher. Farmers are not required to report an attack to BIJ12. ​​Moreover, only attacks where it has been established with certainty that the damage was caused by a wolf are included. BIJ12 has now processed almost all reports for the first half of 2025.
ANP
nyrjoh
#892091Tydligen kan vargar hoppa.
https://www.bild.de/politik/inland/wird ... 26bcae8565
HannuRöj
#899304😀 I Finland uppdateras äntligen lagstiftningen.
Kopia från regeringens färska meddelande:
Regeringens proposition till riksdagen med förslag till lag om ändring av jaktlagen
PROPOSITIONENS HUVUDSAKLIGA INNEHÅLL
I denna proposition föreslås det att jaktlagen ändras.
Propositionen grundar sig på den ändring av habitatdirektivet som gäller vargens skyddsstatus.
Enligt propositionen ska den bestämmelse enligt vilken vargen är fridlyst året om strykas ur
jaktlagen. Fredningstiden för varg ska enligt förslaget regleras i jaktförordningen. I lagen
föreslås även ändringar av teknisk natur.
Propositionen hänför sig till regeringsprogrammet för statsminister Petteri Orpos regering,
enligt vilket rovdjurspolitiken ska skötas på ett sätt som också beaktar social hållbarhet. I
regeringsprogrammet konstateras det att stamvårdande jakt på stora rovdjur tryggas genom
lagstiftningen och att det arbete som redan inletts för att möjliggöra stamvårdande jakt på varg
fortsätter i enlighet med riksdagens beslut.
Den föreslagna lagen avses träda i kraft den 1 januari 2026.
