Skotare
Valmet 840.3 - Engine Fuel Delivery Pressure LOW
5 inlägg 2531 visningar 1 följer Svara, dela mm...
sousa
#524222 Hello,
My 840.3 is giving me the following error:
"Engine Erros
Engine Fuel Delivery Pressure LOW"
Have any one experienced this?
Rottne skotare
Re: Valmet 840.3 - Engine Fuel Delivery Pressure LOW
skogsjan695xl
#524223 Have you change the fuel filter?
On top of the fuel filter is a electric pump. In that pump is kind ordinary it will stuck dirt.
Sorry bad English.
sousa
#524248 Thank you, i understand :-bd
Filters are new, ill check the Eletric pump
skogsjan695xl
#524253 If i remember correctly next to the main power switch. It's a switch on the fuel line as well. Check the hose connectors, i think it is two 45 degrees hose connector. In these 45° it aslo kind regular dirt will stuck.
sousa
#525051 Hi,
We have tried it all, next step is to clean from filters to the deposit, if it works ill post :-bd
