ons 09 jan 2019, 09:28#543155
Nya Nissan Leaf e+, 62kWh är lanserad.
Ca 400km i räckvidd, 214hk och 100kW snabbladdning.
Tyvärr ej vätskekyld batteri och Chademo verkar det som.
"The Nissan LEAF e+ features a new version of the Nissan LEAF’s revolutionary electric powertrain, delivering excellent energy efficiency and robust torque and power output. While the Nissan LEAF meets the needs of many customers with its driving range of up to 322 km (estimated WLTC Japan cycle)*4, near-silent operation and smooth and responsive acceleration, the Nissan LEAF e+ offers more than 40% additional range of up to 458 km (WLTC Japan cycle), allowing customers the ability to do more between charges.*5
The high-capacity battery and more powerful motor in the LEAF e+ combine to produce 160 kilowatts of power and 340 Nm of torque, enabling faster acceleration when driving at high speeds. Accelerating from 80 kph to 120 kph is nearly 13% quicker. This allows the LEAF e+ to confidently pass slower-moving vehicles, exit corners faster and more seamlessly and merge easily with fast-moving traffic. The top speed has increased by approximately 10% for comfortable cruising.
Thanks to an available new 70 kW (100 kW peak) Quick Charging system, the 2019 Nissan LEAF e+ can charge more efficiently than ever.*5 Based on early testing, Nissan LEAF e+ owners can expect similar charging times when hooked up to a 100 kW charger as current Nissan LEAF owners do with a 50 kW charger, despite a 55% larger battery storage capacity.
Den som har mest korrekt information vinner.
