tis 22 nov 2022, 20:06#780285
Williamm skrev:Sq har tvÄ raka eggar. goofy har en rak egg en rundfilad egg.
DĂ„ kan du förstĂ„s fĂ„ informationen direkt frĂ„n âOregonhĂ€stensâmun, sĂ„ att sĂ€ga..đ. What Kind of Square File Should You Use?
Only use files specially designed for square-ground chisel cutters, available from your chain saw dealer. There are three different types of square files: hexagon, double bevel, and âgoofyâ.
The most popular file type is the hexagon shape, also known as âtriangular chisel fileâ. True to its name, a hexagonal file has six sides, plus three corners which act as the filing edge. Out of the three file types, the hexagonal file is the smallest in size and usually fits well into 3/8â pitch chain.
The other two file types â double bevel and âgoofyâ have two corners for sharpening and also allow people to lower depth gauges with surfaces on the top and bottom of the file.
