Bilder på filning.
2328 inlägg 475591 visningar 88 följer Svara, dela mm...
Re: Bilder på filning.
Skeans1
#776917
Alex Strömberg skrev:
Not from oregon or Stihl themselfs. We dont even have skip chains here. Only full and semichisel in full comp. And in 3/8 Stihl is .063 and Husqvarna .058.[/quote]
75 is 63 gauge CL is full comp square chain, I’ve never seen 58 gauge out here. Most of the 28” plus bars out here you buy are 63 gauge once in a great while you’ll see a 50 gauge bar.
Skeans1
#776918
Björn T skrev:Nu mer köper jag bara rullar på 30 meter, från Frawlys saw shop i USA. Mycket bra sortiment.
You might also try Madsen’s the last time I bought a 100’ roll a year or so back they were cheaper then Fraley’s by over 50 dollars for 75CL Oregon chain and Stihl was the same price.
Skeans1
#776919
Mange skrev:Oregon i Sverige vill inte ta in square eller skip.
Inte heller sälja 25ft rullar längre...
Rätt dåligt kan jag tycka.
Anders.
Halvmejsel är det om det inte är mejsel eller skovel utan nåt mellanting.
Microchisel är en benämning som är en av många pruduktnamn.
Why buy quarter roll when a 100’ is the standard packaged roll length or 1640 drivers of chain? Buying 25’ at a time you’re loosing money that there’s no price break vs buying in bulk.
Mange skrev:Nä du, Anners bus...
Du får allt guggla lite på svenska.
Camfer o micro chisel är inte nån universal benämning på tandtyper som finns utanför Blounts kataloger.
Vad geter Stihls Camfer?
https://www.thedailygardener.com/chainsaw-chain-types Googla var det som sagt.. 😀
#776926
Skeans1 skrev:Why buy quarter roll when a 100’ is the standard packaged roll length or 1640 drivers of chain? Buying 25’ at a time you’re loosing money that there’s no price break vs buying in bulk.
I am a small man, not so big wallet so I can have 100ft rolls of 20 chains.
I try to use what works best for the custemer and his needs. Easier if all had same, but as all are not doing same work, same way with same saw there is gains to get by choosing cutting system carefully....
Björn T
#777018
Madsens is cheaper but, they dont ship to Sweden. Much more easy to order from Frawlys on eBay. All import charges is paid with eBay.
forest.
#778256 Måste alla tänder på en kedja vara lika långa eller kan de var olika långa?
forest. skrev:Måste alla tänder på en kedja vara lika långa eller kan de var olika långa?
De kan vara olika långa såvida du justerar ryttarna..🙂👍
forest.
#778259
Ja filar du bara de tänder som är skadade och sen justera alla ryttarna?
#778263 Du treng berre justera ryttarane til dei tenna du har filt, men eg hadde for sikkerheits skuld sjekka alle ryttarane. Var det foresten det du meinte?
#778298 Lika vasst och lika vinklar är viktigare än lika längd, bäst är naturligtvis lika allt men det är sällan praktiskt möjligt.
#778301 Är någon enstaka tand skadad filas den vass sen åker den med och jobbar nog mindre, men påverkar inte mycket.
Är det många på båda sidor skadade filas alla vasst och ryttare justeras individuellt till var tand.
Är någon tand inte skadad filar jag ofta denna till samma längd så är det lättare med ryttarställning.
#780183 Square ground och rundfilning i kombination..🙂👍.
Ent
#780230
anersimyra skrev:Square ground och rundfilning i kombination..🙂👍.
Tres bien! Synd att man inte behärskar franska eller att han visade nån före/efter. Vad är poängen med kombinationen, är rundfilningen för att få ett rymligare spånutrymme?
Han säger enligt en kommentar till filmen att en rundfilad tandsida skär effektivare än om den enbart filats till en SQ profil. Filningen ger alltså en kedja med maximalt bra egenskaper från både SQ och rundfilning..👍🙂
