Skotare
Osa 250 no drive to rear wheels.
24 inlägg 4301 visningar 4 följer Svara, dela mm...
Re: Osa 250 no drive to rear wheels.
Krzysiek
#698293 Hello, there is no charging in the wasp 250 where to look for an alternator failure, good fuses too
AKKAMAAN
#698353 lyser laddnings kontroll lampan när du vrider på tändningen?
Kontrollera att den lampan är hel
rengör och dra åt alla batteri anslutningar
anslut nyladdade batterier
starta dieselmotorn
Vilken spänning kan du mäta på batterier och på alternatorn?
does the charge control light come on when you turn on the ignition?
Check that the lamp is intact
clean and tighten all battery connections
connect freshly charged batteries
start the diesel engine
What voltage can you measure on batteries and on the alternator?
czy lampka kontrolna ładowania zapala się po włączeniu zapłonu?
Sprawdź, czy lampa jest nienaruszona
oczyścić i dokręcić wszystkie połączenia akumulatora
podłącz świeżo naładowane akumulatory
uruchomić silnik wysokoprężny
Jakie napięcie można zmierzyć na akumulatorach i alternatorze?
Krzysiek
#698367 The lamp is not lit, the tachometer also stopped working, the motor burns without a problem, is there a charging fuse?
AKKAMAAN
#698430
Krzysiek skrev:The lamp is not lit, the tachometer also stopped working, the motor burns without a problem, is there a charging fuse?
There is a fuse #9 for all control lamps and the tachometer. Follow cable marked #7 from the fuse board to charge lamp and tachometer under the dashboard. There has to be 24+ Volt under the dashboard. If the lamp still is not lit when you turn on the ignition it is broken. Replace it with a bulb that works!
Krzysiek
#698441 And one more question does not work rear wuzek in general how to wlonczyc it?
Krzysiek
#698442 Sory, I am asking this. I bought a machine like this for the first time two weeks ago
Krzysiek
#699305 Hello, I have a problem, the rear wheelchair does not work, someone will tell you where to look for the fault
AKKAMAAN
#699379
Krzysiek skrev:Hello, I have a problem, the rear wheelchair does not work, someone will tell you where to look for the fault
You have to improve your Polish to English translations...
This is a wheelchair...
Here is a link to all manuals
Instruktionsbok=Operators manual
Verkstadshandbok=Repair manual
Reservdelskatalog=Spare parts catalogue
Here are some pages about high/low gear and all-wheel dríve or power to your "wheelchair"...
It is all in Swedish and you can start to browse the pages and see if you can figure anything out. There is a coupling called "Scania koppling" that connects the power to the "wheelchair" (rear end).
The Scania koppling is located just behind the gearbox. Depending on the serial number on your machine it can be operated hydraulically. Later models are operated pneumatically (pressured air)...
Krzysiek
#700008 Hello, there is some stabilizer of the wheelchair wylniu because I will take a block and it turns it over
Eco Log skördaraggregat
