Skördare
RPM sensor Valmet 911.1
2 inlägg 2560 visningar 2 följer Svara, dela mm...
Logmax bild
emanuelmelodesousa
#499635Hello,
I´m having a problem with a Valmet 911.1 2001 (without ECU). I´ve changed the computer (had a regular laptop), the machine had Terman 2.2.5, and after mounting/instaling the new computer i installed (upload VBU?) again with Terman 2.2.5. (i copy everything from the original settings, 911.1, CRH16, Gessman, etc etc etc)
After all this, the machine stopped counting RPM, we have checked the wire to VBU, ground wire, all ok. I noticed that theres no energy reaching the sensor (from VBU 0 Volts).
Any suggestion? :| :| :|
Thankx in advance.
Re: RPM sensor Valmet 911.1
Kjerrman
#500857Would not surprise me if you have to reload the program in the vbu. Happend to me when the upstart procedure is interrupted.
Nordfarm slirskydd
