Skotare
Osa 250 no drive to rear wheels.
24 inlägg 6572 visningar 4 följer Svara, dela mm...
ELFINWOOD
#328004 Osa 250 problem, no drive to rear wheels! Had a driver on it yesterday as i was busy winching and this morning he say it gets stuck easy? So had a quick look and there is no drive at the rear wheels, rear prop is turning and taking drive into the rear diff, so halfshafts or drive chain problem? He said he never heard any noise. Any advise or diagrams or parts, so now i,ve got 2 forwarders that only drive on the front bogie1 At least i have the parts to sort out the Bruunett.
Rottne skotare
Re: Osa 250 no drive to rear wheels.
Åke Nilsson
#328511 check if the splines in shaft between front and back section is broken.
ELFINWOOD
#328556 Thank you for your reply, the problem was the hex head bolt in the outer end of the halfshaft that holds it in to the drive sprocket, it had come loose allowing the halfshaft to slide out of the sprocket in the bogie, so i pulled the shaft back in to place and tighten the hex head bolt, It took ten minutes to do and no cost :lol:
åberg
#328564 Congratulations then! :smile:
Krzysiek
#697766 Witam mam problem z osa 250 zacia się ktorys elektro zawór od kierowania dzojstikiem non stop jest zalonczony nie mogę odpalić maszyny bo go czy a olej panowie pomoże ktoś 🤔
skogsjan695xl
#697768
Krzysiek skrev:Witam mam problem z osa 250 zacia się ktorys elektro zawór od kierowania dzojstikiem non stop jest zalonczony nie mogę odpalić maszyny bo go czy a olej panowie pomoże ktoś 🤔
English please.
Krzysiek
#697892 Hello, I have a problem with the wasp 250 jammed any solenoid valve from the joystick turn I can not start the machine because it holds oil, how to unlock which section on the manifold
#697896 Plug the 1/4 hose marked "ls"
Goes from the hydraulic valve and control the hydraulic pump
It is the only 1/4 hose at the pump
Krzysiek
#697899 Sterowanie było ok przelonczylem na sterowanie na dżojstik i maszyna skręciła i dalej chcę kręcić elektrozawor jest wlonczony ale nie wiem który to jest?
Krzysiek
#697901 The control was just switched to the joystick control, you started to control and automatically the machine itself turned max and I still want to turn which electro valve to disconnect it, I can not start the machine no
#697910 Crane or drive?
Krzysiek
#697935 The crane itself turns left approx
Krzysiek
#697936
Krzysiek skrev:The crane itself turns left approx
Drive
#698120 At drivepump 2 Hirchmanconnectors unlock then try again
If machine still moves or you vant start pump is broken
AKKAMAAN
#698146 Jaki jest numer seryjny maszyny?
What is the serial number of the machine?
Vad är det för tillverkningsnummer på maskinen?
