Före och efter jobbet
3G Modem Router
1 inlägg 1525 visningar 1 följer Svara, dela mm...
Re: 3G Modem Router
keja01
#132210 In Sweden 3G at frequency 450 MHz from provider Net1 is reliable. Their currently best all in one wireless modem router is called D35 and uses no SIM-card.
Other 3G systems uses 2100 MHz from either Telia, Tele2, Telenor, Tre. Line of sight to a 3G-site is needed for higher speed. More important at higher frequency. Use a simple mobile phone set to "3G only" to test reception before buying. GSM reception must be inactivated for this testing. Switch between SIM-cards in the phone to compare different companies.
