Tigercat 1085
Komatsu bild
 Svara  36 inlägg  21963 visningar  9 följer
Tigercat 1085
#289976 Äre nån som vet nåt om Tigercat 1085? Efterträdare till 1075b.... ska kunna lasta 24 ton virke. jag vill ha mer information om detta monster till storskotare!!!!
Re: Tigercat 1085
#290019 Hej,
Intressant. Jag har inte hört något. Är det någon av er som har mer info eller rykten, skriv gärna här!
Re: Tigercat 1085
#291699 Tigercat testar 1085 och förhoppningsvis kommer den i produktion till nästa år.Den ska tydligen ha boggielådor och transmission lika som på skiddrarna,vilket gör att max fart blir 8 km/tim.Motorn kommer från Iveco
Re: Tigercat 1085
#294274 The (25-tonne) 1085B very similar to the 1075B except with higher capacity bogies and a standard oscillation lock to accommodate the new (standard) Tigercat F195T85 high capacity crane.
Here is some some top secret information on the new crane:
The new heavy duty F195T85 crane is capable of lifting 20 to 30% heavier loads and has 22 to 66% more
slew torque than any other competing crane on the market. The crane geometry is optimized for quick loading
and unloading cycles with excellent grapple clearance above the load. It is also the only crane that can handle
a 0,53 m2 grapple (which Tigercat also makes), a great advantage in smaller diameter log applications.
The F195T85 is the only crane with standard end-of-position dampening sensors on the stick and main booms
to prevent impact loads. The tapered roller bearing in the slew base is designed to last the life of the machine,
a vast improvement over the plain bearing and spherical rollers used in other cranes. It is also the only crane
with swivels on the pillar hoses for extended hose life, thick walled bushings used at all pivots and a cushioned
telescopic cylinder.
Best Regards,
Paul Iarocci | communications manager
Tigercat Industries Inc.
T: 519.753.1539 ext. 4314 | M: 519.755.1788
Mail: P.O Box 637 Brantford ON, Canada N3T 5P9
54 Morton Avenue East, Brantford ON, Canada N3R 7J7
Re: Tigercat 1085
#308989 Hej,
Det verkar inte finnas så mycket info om Tigercat 1085b ännu.
Tack för infon Lill-junior.
Har hittat en bild hittills, se den nedan.
Re: Tigercat 1085
#309044 Hej!!
Ja där ser man vilken batting till skotare som kommer på skogsmarknaden................
Re: Tigercat 1085
#321924 nu finns den på deras sajt.
http://www.tigercat.com/product/1085b-forwarder/
Re: Tigercat 1085
#321932 Hej,
Den är rejäl, den nya 1085b!
Väger in på drygt 27ton, lastar 25ton!
Lyftkraft för kranen också imponerande 195kNm.
Med bredaste lastutrymmet borde det gå på 38m3t.
Re: Tigercat 1085
#321939 Någon som vet vad Widerange transmissionen är för något?
Tyckte inte att man hittade så mycket info om den på hemsidan.
Re: Tigercat 1085
#321942 Hej,
Ja, jag läste det som snabbast också.
Det står ju lite fattigt om det i broschyren också, fritt översatt:
Hydrauliska motorer med 2 kolvar, oändligt variabla.
Kan det vara likt Gremo VT?
Måste vara fel i broshyren för det står ju bara att hastighetsområdet är 0-7,9 km/h i ett steg. De andra skotarna i broschyren är ju mer konventionella med växling i 2 steg. Kanske gör den 0 ~17km/h i ett steg?
Re: Tigercat 1085
#327709 tack för info...........
Re: Tigercat 1085
#327881 Första videon på 1085b.
Länk till videon på YouTube:
https://www.youtube.com/watch?v=ZzMyXO9IAA4
Re: Tigercat 1085
#327884 Ser brutal ut! :grin:
Sv: Tigercat 1085
#338732 Hej,
Här är en video till, bl a på 25 tons monstret 1085b.
Spännande också med "hooked crane", alltså att kranen går att få med knäckt huvudbom för att sikten ska bli bättre. Tror ni på det?
https://www.youtube.com/watch?v=WFSwmXVRp6M
Re: Tigercat 1085
#348666 Transporthöjden kan ju bli ett problem med den knäckta bommen, lägger man band och annat på kärran kan den vara svår att få ner i höjd känns det som.
Tigercat 1135, ersättaren till Tigercat H09 av Fredrik Reuter - tis 09 mar 2010, 16:48
i Skördare
12
28 svar
15770 läst
av Fredrik Reuter
fre 01 jul 2016, 11:08
tigercat ho9 av skogsoxen - mån 28 jan 2013, 14:31
12
16 svar
7524 läst
av nutte
tor 31 jan 2013, 19:05
H8, Tigercat H09, Forestline C90 ??? av Seb macahan - ons 22 jan 2014, 14:11
i Skördare
12
24 svar
10924 läst
av jonathanA
tor 20 feb 2014, 23:35
tigercat h09 är den bra eller av american logger - tor 27 okt 2011, 19:37
5 svar
2539 läst
av nutte
sön 30 okt 2011, 06:47
Tigercat info av alfha - ons 18 jul 2012, 19:38
i Skotare
8 svar
3835 läst
av wrytter
tor 19 jul 2012, 21:41
